by mike.smith » Wed Jan 08, 2020 11:09 pm
I'm going to say things that are probably obvious to seasoned aircraft owners, but I'll say them anyway.
My analysis is done by Lab One Aviation. The elements tested for are fewer than those in the Blackstone report. Probably why the Lab One testing is cheaper. I see Iron, Chromium, Copper, Tin, Aluminum, Nickel, Silver, Silicon, Phosphorus, Molybdenum, Titanium.
I'm not a chemist, but I'll bet differences in testing technology used by different companies will yield different relative numbers. So comparing numbers between different testing services may not mean much.
As someone whose early oil analysis trends revealed my nickasil cylinders going bad (nickel and aluminum took obvious turns upward), and who now has 6 years of oil analysis on the same engine, I can state two things I believe are truisms. 1. Looking at individual numbers is nearly meaningless, and only serves to get your undies in a bunch for no reason. Lighten up, Francis... 2. What you're looking for is TRENDS. So unless you see some obvious out of place big honking number, just watch the trends between oil changes. If you seen something moving constantly upward, now you have something you can hang your hat on and look for the culprit.
Incidentally I don't believe there is any reason to use any kind of sealant on the cork gaskets for the rocker covers. The cork IS the seal. Sealant just makes removing and replacing the gaskets that much more difficult. I've never used sealant and never had a leak. My two cents.
