cylinder to case seal
Postby Johns » Wed Aug 14, 2019 9:09 am
Having a problem with #1 and 2 cylinder side of motor leaking from the base of cyl to the case at higher rpms.(Above 2,000) Looks more like # 2. I recently had the motor home and cleaned everything, resealed everything with Permatex aviation form a gasket #3 and it still leaks. Not as bad as before but enough to keep me grounded.
Anyone else have this problem? Maybe a different sealer? Ideas? John
Johns
Re: cylinder to case seal
Postby wmbarber » Thu Aug 15, 2019 7:22 pm
I have the same problem but mine appears to be the number one cylinder and has occurred with both Permatex and RTV red. Hopefully someone has some suggestions. Otherwise how many have had success with the Permatex verses sucess with RTV?
Pete
wmbarber
Postby Onex107 » Thu Aug 15, 2019 8:44 pm
Crazy suggestion. If you have shims under the cylinder you have to seal each one also.
Postby Johns » Fri Aug 16, 2019 6:39 am
Yes, I have shims and I did seal both sides. That is what so frustrating, I am sure I did it correct. Ready to bring it home and try again.
John
Johns
Postby kmacht » Fri Aug 16, 2019 7:51 am
If it is a new issue have you taken a good look at the crankcase vent? Building up even a slight positive pressure in the case can cause leaks.
Postby Area 51% » Fri Aug 16, 2019 8:13 am
Are you sure the leak isn't coming from the hold-down studs?
Postby Johns » Fri Aug 16, 2019 9:01 am
I am pretty sure they are all blind holes on that side. Correct me if I'm wrong. John
Johns
Postby Area 51% » Fri Aug 16, 2019 11:26 am
The back 2 studs on #1 cylinder go all the way through into the case. PM me your email address and I'll send you a picture.
Postby lutorm » Sat Aug 17, 2019 2:07 am
Johns wrote:Yes, I have shims and I did seal both sides. That is what so frustrating, I am sure I did it correct. Ready to bring it home and try again.
John
On my case, the cylinder stud "case saver" inserts protruded slightly above the cylinder base, so the shim would not lie flat against the base. I had to (very carefully) dremel down the inserts where they run under the shim. It's described, with a picture, here. Are you positive yours don't have the same issue?
lutorm
Postby Johns » Sat Aug 17, 2019 10:53 am
Lutorm, I have the engine home and that is on my list of things to check although I did check them already. There has to be something I am overlooking.
Thanks everyone, John
Johns
Users browsing this forum: dreyn96 and 24 guests
