Ryan,
Kerry sent me this when my turbo stuck. The last paragraph has a link to a procedure to fill turbo bearing with B-12 chemtool and soak for 24 hours, this freed mine up:
Alternate Cause Theory and Optional Service Procedures:
Since the publication of Revision A of this service bulletin, no new turbocharger seizures have occurred in the factory or customer AeroVee Turbo fleet, and Sonex Aircraft has therefore not had an opportunity to analyze a seized turbine shaft “piston ring” type seal for possible rust deposits. Tornado Alley Turbo Inc. service bulletin TAT SI15-02 (
http://www.taturbo.com/TAT%20SI15-02%20 ... turbos.pdf ) and related Continental Motors service bulletin M71-21 (
http://www.tcmlink.com/pdf2/M71-21.pdf ) present a plausible theory regarding the cause of AeroVee Turbo turbine shaft ring seal seizures that is alternate to coked oil deposits as a cause of the seizures. These service bulletins state that rust deposits in low time (under 100 hours) turbochargers are the cause of turbine shaft ring seal seizures that have occurred in the applicable type-certified and STC turbocharger installations. Per the Tornado Alley service bulletin description:
"This condition occurs when the turbocharger is new or newly overhauled and heat and normal operation have not yet formed a protective layer on the internal parts that protects them against oxidation.
During periods of prolonged inactivity (typically several days to weeks, and more frequently in humid weather) these deposits from oxidation may cause a restriction so that on initial engine start up, the turbocharger does not spin up."
All AeroVee Turbo seizures to-date have occurred on turbochargers with less-than 100 hours, and prolonged periods of inactivity are common in VFR recreational aircraft such as the Sonex line of aircraft due to inclement weather and/or personal schedules. Therefore, Sonex Aircraft strongly suspects this alternate cause as a possible major factor in AeroVee Turbo seizures.
The above-referenced service bulletins prescribe troubleshooting remedies involving penetrating oil to free-up seized turbochargers that may be followed by AeroVee Turbo customers.
Note, however, that the Continental Motors service bulletin states:
"Units which are binding after long time service are coked internally and must be removed for cleaning or replacement."
Additionally, turbocharger STC vendor RAM Aircraft publishes an annual solvent flush procedure as preventative maintenance that may be utilized by AeroVee Turbo owners (
http://www.ramaircraft.com/Maintenance- ... -Turbo.htm ). Note that the turbo oil supply and oil drain lines must be disconnected to isolate the turbo from the engine’s oil system during this procedure, and that a thorough mineral spirits flush (may require several ounces of mineral spirits) must be made to remove any loose particles from the turbocharger before reconnection to the engine’s oil system. Sonex Aircraft has used the Berryman B12 Chemtool solvent prescribed in the RAM Aircraft flush procedure to free a seized turbo before return to the turbo manufacturer for overhaul, and found the solvent to be effective.
