VDO pressure sender
PostPosted: Tue Jun 18, 2019 12:28 pm
by Onex107
Has anyone found a source for the 0-80 psi sender that costs less the $50? It's failing at 250 hours.
Re: VDO pressure sender
PostPosted: Tue Jun 18, 2019 1:42 pm
by WaiexN143NM
hi all,
Try the swift press sender avbl from aircraft spruce.
#04056 0-150 psi
#04057. 0-100 psi
1/8 npt
WaiexN143NM
PostPosted: Tue Jun 18, 2019 7:47 pm
by Onex107
The MGL EFIS recommends 0-80 psi. and only take one wire to the panel. What's the three wires for on the Swift?
PostPosted: Tue Jun 18, 2019 9:32 pm
by XenosN42
250 hours? Count yourself lucky - no very lucky. Buy another VDO.
PostPosted: Wed Jun 19, 2019 2:18 am
by WaiexN143NM
onex 107, all,
the swift has 3 wires, +5v, gnd, and signal. john austin on the zenith site has a detailed posts on how to hook up the swift sender to MGL equipment. posts were last fall.
www.zenith.aero
hope this helps......
u could just buy another vdo for the same price, but expect it to fail again in about 200 hrs.
michael.
