Alternate Baffle Seal
Postby NWade » Fri Mar 29, 2019 11:41 am
All -
Like many others I've had a dickens of a time with the default rubber seal material supplied with the kit - it is *so* hard and unyielding that I cannot get the baffles trimmed to a good level that allow for sealing without requiring so much force that the fiberglass cowling distorts. The rigid leg of the "D" seems to really resist compression! I've re-trimmed my fence baffles 3 or 4 times trying to find the "sweet spot", but still can't get a good compromise of consistent sealing while allowing the cowling to sit (or be pulled down with fasteners) without major distortion.
Anyone have thoughts on this alternate seal available at McMaster-Carr Aerospace?
https://www.mcmaster.com/9141K117
This version of the "D" or "P" shaped baffle seal is much more pliable. If it was barely contacting the cowling on the inside then I'd be worried about it "blowing out" under pressure and allowing the air to leak past the top of the engine instead of being directed down through the cylinders; but if its compressed quite a bit (i.e. your baffle itself is within a quarter-inch of the cowling) then the thick foam compresses down strongly and seems like it'll hold.
The major downside is that this material is only rated up to 350 degrees F. On the one hand, that seems low compared to most engine compartment items. On the other hand, if something in contact with the fiberglass cowling is 350 degrees, the cowling itself will be melting already, right? CHT redline is 450, and realistically you probably don't want it above 380 or so for any length of time (per Mike Bush) and the baffle seals are several inches away from the heads... so they shouldn't get anywhere near that hot in normal ops, right?
Anyone have thoughts; or any actual measurements of under-cowling temps after shutdown (with the attendant heat-soak)?
--Noel
Re: Alternate Baffle Seal
Postby racaldwell » Fri Mar 29, 2019 12:43 pm
Noel,
I can't answer your question on the D seal but here is an alternative solution that I used when I ran into the baffle seal difficulty way back when I was building my RV6. I started cutting rubber for the seals on a Saturday morning and soon realized that I needed 19 pieces and getting all to seal 100% didn't seem likely. So I switched gears, dug out some scrap extruded poly foam and put it between the aluminum baffles around the engine. Less than an hour with a surform plane and sandpaper, the shape was done where it just fit under the cowling. I taped on some Seran Wrap, mixed up some old Safetypoxy and laid on about four plies of 6 oz, Eglass, with more around the edges. By the end of the day, the resin was set up enough to remove it to get the foam out, trim the edges where needed, and push the laminate back in position for a tight fit onto the baffles for a full cure overnight. Yep, one day to make the plenum and rid the hassle of fitting rubber seals. But it took the rest of the next week of evening work sessions to fit the rubber strips to the top cowling to seal the inlet to the plenum.
That was done in 1999 and I now have 1011 hrs on it. This is a picture from last month during the annual inspection (prop overhaul, etc.) and the engine temps have not bothered the plenum materials. My Lycoming in an RV6 cowl runs in the 400-425 F range so it is hotter than what you will see. My recommendation is to make a plenum. Also keeps the forces on the cowl to a minimum.
Plenum
Rick Caldwell
Xenos 0057
racaldwell
Postby kmacht » Fri Mar 29, 2019 3:05 pm
I went with this when building my plane:
https://www.aircraftspruce.com/catalog/ ... ckkey=3611
I trimmed the metal baffles about a 1/2" short of reaching the cowling and then left about 1.25" of the baffle material sticking out above that. I ran it all the way around in one continuous piece from the front of the cowling, across the back, and back to the front on the other side. It is held on with rivets and backing strips made from aluminum. After 100 hours of flying it is holding up well. The material folds inward when I put the top cowling on so the harder the air blows the tighter the seal gets against the cowl. I think I had the baffles trimmed and the seal installed in about 2 nights worth of work. It seemed much easier than trying to get a perfect trim with the p-seal.
Postby lutorm » Fri Mar 29, 2019 6:37 pm
racaldwell wrote:Noel,
I can't answer your question on the D seal but here is an alternative solution that I used ...
Nicely done! This is the way to go I think. How complicated is it to remove/install when needing access to the engine?
lutorm
Postby Bryan Cotton » Fri Mar 29, 2019 7:59 pm
It does look nice. How much does it weigh?
Postby racaldwell » Mon Apr 01, 2019 8:44 am
To answer your questions, there are 18 screws to unscrew to remove the plenum. With a screwgun, maybe 2-3 minutes to remove. The screws have nutplates (#8) and are SS.
I haven't weighed the plenum. I would guess maybe 1 lb. It's not much. The rubber baffle seals weigh much more. Those are sitting in the junk cabinet in the back of the hangar.
I will be doing this again when the time comes for my CAMit 3300 installation.
Rick Caldwell
Xenos 0057
racaldwell
Postby Rynoth » Mon Apr 01, 2019 3:03 pm
I used the product Keith linked for much of my baffle seal, and ended up with a combination of both seals.
The Sonex-provided "D" seal worked well enough when it was perpendicular contact with the cowling, but I liked the wider/softer (orange) silicon flap seal where it met the cowling at an angle, and/or where the gaps between baffle and cowling were larger than ~1/2 inch.
Postby Bryan Cotton » Mon Apr 01, 2019 10:23 pm
My roll of baffle material weighs 0.814 lbs.
Postby Darick » Tue Apr 02, 2019 8:18 am
Yep, same problems here...solved with the red baffle seal from ACS...see page 16 on the photo album Darick's Sonex...
I also noticed the factory seal, which I kept in place at the sides and front, and have come in contact with oil, have become sticky, soft, gooie which is a sign of incompatibility with oil. I suspect it may be EPDM rubber (ethelyene propolyene) used mainly for water exposure. Silicone rubber, the red stuff sold by ACS for baffle seal, has the best qualities for heat and oil resistance.
Not to blow my own horn but, my work experience for 30 years in the fluid power business was solving problems with sealing devices made of all kinds of rubber and plastics...buna/nitrile, viton, Teflon, nylon, etc.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Bryan Cotton » Wed May 01, 2019 10:01 pm
Here we got our rear and side baffles installed as one piece.
This corner is puckering up. The seal in the previous picture is one continuous strip. I snipped the corner a bit but it still doesn't behave. Any suggestions?
Users browsing this forum: Google Adsense [Bot] and 14 guests
