Aerovee cylinder baffles
Postby ProfJ » Wed Dec 26, 2018 8:53 pm
Hey Folks,
Does anyone know where I can purchase a set of the black steel cylinder baffles seen in this photo? Can't find them on the Aeroconversions site...
Jon
ProfJ
Re: Aerovee cylinder baffles
Postby ProfJ » Wed Dec 26, 2018 8:57 pm
OK, found them at Aircooled.
ProfJ
Postby lutorm » Thu Dec 27, 2018 12:58 am
Those are mounted up side down, they go on the bottom of the cylinders.
lutorm
Postby Stogie6 » Thu Dec 27, 2018 7:58 am
Super tins...yep, on the bottom just above the push rod tubes! Snap right on.
David F. Jones
Memphis (Mud Island), TN
Aerovee powered Onex
N153TD
Based at KAWM and in the midst of Phase 1
Stogie6
Postby ProfJ » Thu Dec 27, 2018 12:44 pm
lutorm wrote:Those are mounted up side down, they go on the bottom of the cylinders.
If you were setting up for updraft cooling rather than downdraft (in a pusher setup) would you switch the tins top to bottom, or keep them on the original sides? (assuming you had the original top tins also.) Seems to me that their shape will be optimized for airflow direction?
ProfJ
Postby lutorm » Thu Dec 27, 2018 12:57 pm
Yeah i guess if you have updraft, you'd want something on the top. But I don't know if they'll fit, the cylinders are symmetric, but the heads aren't symmetric top vs bottom.
lutorm
