by lutorm » Sat Dec 30, 2017 3:39 am
I've been learning as much as I can about aircooled VWs while rebuilding the Aerovee, and one thing that seems weird to me is that the manual specifies a 8.0:1 compression ratio when running 100LL. This seems very low. People regularly run 9.0 or 9.5 in cars with premium pump gas. Of course, the safe compression ratio depends on the cam in use and we also regularly run extended full throttle at relatively low RPM.
Maybe they just wanted to have real conservative detonation margins? But then the real weird thing is that they also specify 8.0 in the Turbo. If it's safe to run 8.0 at 40" MAP with the turbo (with no intercooler, no less), it should definitely be safe to go a lot higher on the CR when naturally aspirated.
Ignoring intake temp differences, cylinder pressure should scale roughly as MAP * CR^gamma where gamma is something like 1.2--1.4. So, if we can safely run 40*8.0^1.2 = 485"Hg cylinder pressure in the turbo, we should be able to run (485/30)^(1/1.2) = 10.2 naturally aspirated. (If we use gamma=1.4 instead, we get 9.8.)
Moreover, I just measured my combustion chamber volumes and concluded that the actual compression ratio is actually lower than what is indicated by the table in the Aerovee assembly manual. Those tables assume a 55cc chamber volume, but I'm getting it's more like 58cc, presumably because of the extra spark plug hole. This means that if you aim for 8.0:1 with that table, you actually get more like 7.7:1. (The cylinders also have about a 2cc spread in volume, so this also translates to a difference in compression ratio for the different cylinders of maybe 0.2. I'm in the process of grinding away material to even that out.)
Has anyone tried increasing their compression ratio?
