Case vent tube
Case vent tube
Postby Darick » Fri Aug 25, 2017 10:22 pm
The case vent tube is normally cut at a 45 at the end where is exits the cowl. Is this to face forward, which would theoretically cause positive pressure into the case OR the cut facing aft which would theorletically cause negative pressure. There is one picture in the manual showing fabrication of the bottom cowl air exit baffle. In this picture the vent is facing forward, but there is no reference to the vent in the instructions. I'm using the oil separator too if this makes a difference.
Thanks.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Case vent tube
Postby Darick » Wed Aug 30, 2017 10:27 pm
Guys, Kerry answered my question...
"The oil breather tube does not need to be cut at any particular angle but
should NOT face forward. It can face down or aft. Some people (myself
included) had the oil breather drip onto an exhaust pipe so any oil that
existed it would burn up rather than streak the bottom of the airplane."
Darick Gundy
Sonex #1646
N417DG
Darick
Re: Case vent tube
Postby kevinh » Wed Aug 30, 2017 11:12 pm
Speaking of that - yeah. I had the breather drip onto the exhaust stack (about a 1/8" - 1/4" gap) on my RV and that was how Van's recommended it. Worked good.
Also this thread might be interesting to you: http://www.vansairforce.com/community/s ... p?t=126270
kevinh
Users browsing this forum: No registered users and 45 guests
