For all of those running the top mount oil cooler, do any of you have a problem with the cooler contacting the cowl? I was fitting my cowl, and the cowl made contact with the top lip of the cooler, so I started trimming the corner of the lip on the cooler, just like you do on the bottom so the cooler doesn't hit the mount. Then I continued to fit the cowl, and found that the cooler is now hitting the body of the cooler between the two mount bolts and the single mount bolt. Hopefully you can see what I mean in the pictures.
This picture shows the cooler contacting the cowl in two places, 1 where I was trimming the top lip of the cooler, and more can be trimmed to correct, but 2 where the body of the cooler curves down between the mounting bolts:
https://drive.google.com/open?id=0B4TJg ... 1hnX3Bmb2MThis is a photo of the cowl:
https://drive.google.com/open?id=0B4TJg ... Ux3MURBclEI did not get my cooler from CB, but assumed that all of the type 1 coolers are the same. If you have a cooler that does not have this problem, please let me know if it looks different. If you have an idea as why mine it hitting the cowl, please let me know.
Thanks, Jeff
