Hi All,
Well I've got the AeroVee Turbo successfully
mounted on the aircraft, with
plumbing and wiring to begin very soon. So now I need to stop dithering and pick a prop, otherwise I won't be able to give the engine a good test-run and tune the AeroInjector.
The
AeroVee Turbo Performance Numbers thread has some good data; but mostly covers Prince P-Tip props and doesn't quite give me the info I need to make a final decision.
My airframe has been built to be relatively light (keeping the added extras to a minimum; although the turbo and Sonex hydraulic brakes do add a few pounds). This is because I myself am relatively heavy (215 lbs), and because my most-likely passengers are also on the larger side (185-200 lbs). Where I fly (WA state) has some mountains and desert, and some fun short airstrips. Most are plenty long enough that takeoff roll isn't a problem; but with our tall trees I want to have good climb performance. ESPECIALLY since I know I'll be heavy when I do fly with a passenger! Although I like the idea of max speed, I have decided that an extra ~200fpm climb is probably worth 5-10mph of speed. given my mission. Plus, a faster climb rate also means I can get up to altitude faster and then take advantage of higher TAS numbers (I'll often be climbing to 4000' or 5000' to clear the Cascade foothills & mountains anyways). Plus, the idea of a climb rate less than 500fpm when flying at gross weight on a day with noticeable density-altitude spooks me.
So although I'd love to get the best of both worlds, I think for me the big questions are:
- Between the Prince and Sensenich climb prop, which provides better climb performance?
- If I go with the Prince prop, is the Carbon Fiber version worth ~$250 extra? (Note that I'll be storing the aircraft in a hangar)
Thanks a bunch,
--Noel
Sonex #1339
Center-Stick, Flush-pulled-rivets, AeroVee Turbo, Taildragger (4" tailwheel upgrade), Sport-Acro Ailerons, Sonex hydraulic brakes
MGL Discovery Lite, MGL V6, Trigg TT21, ELT, MGL Infinity Single w/9v battery (night VFR backup instrument)
