Page 1 of 2
ACV-G01-10 gascolator
PostPosted: Sun Jun 11, 2017 11:37 am
by bvolcko38
Where does one purchase the above mentioned gascolator?
PostPosted: Sun Jun 11, 2017 5:58 pm
by kevinh
bvolcko38 wrote:Where does one purchase the above mentioned gascolator?
Aircraft spruce.
Sent from my Nexus 6P using Tapatalk
Re: ACV-G01-10 gascolator
PostPosted: Mon Jun 12, 2017 8:26 am
by Sonex1517
http://www.aircraftspruce.com/pages/ep/gascolators/usher.php
This is the one many Sonex builders use.
PostPosted: Mon Jun 12, 2017 9:39 am
by builderflyer
Just don't buy the ACS gascolator...........note Sonex Revision 10.19.15............as previously reported, you'll want the Usher gascolator. I write from personal experience having had to pull the ACS product from my Sonex to replace it with the Usher. More details are available if anyone cares to know why.
Art,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jab3300 #261
PostPosted: Mon Jun 12, 2017 1:28 pm
by Issak
I have a brand new one that I do not intend to use. It came with the kit I bought. If you want it I can ship it to you for free and it would be $60.
PostPosted: Tue Jun 13, 2017 1:30 am
by Bruce593SX
me too... dont need no stinkin gascolator
PostPosted: Tue Jun 13, 2017 2:44 am
by wlarson861
don't use the gascolator. use a filter and save yourself the burps. Ask me how i know.
PostPosted: Sun Jul 02, 2017 10:14 am
by bvolcko38
You guys that eliminated gascolator...do you have photos or drawings of your filter installation?
PostPosted: Sun Jul 02, 2017 11:59 pm
by wlarson861
I don't have a picture but it is simply on the engine side of the firewall on the fuel line. Then into a stainless steel braided hose to the AeroCarb. Make sure the entire fuel run is downhill with no part of the fuel line lower than the carb inlet. I also used pipe insulation from Menard's homebuilt supply to wrap the fuel line and filter. Covered that with aluminum heat duct tape. burps eliminated! I change the insulation and clean the filter at annual. never found anything in the filter when I opened it.
PostPosted: Mon Jul 03, 2017 8:56 am
by bvolcko38
What fuel filter are you using?
