wlarson861 wrote:I agree with Mike, the first thing to do is put the exhaust pipes on since that will determine the mounting position for the turbo.
wlarson861 wrote:Remember, even though they are welded in a fixture there can be some individual variance in the shape of the exhaust pipes.
WaiexN143NM wrote:Hi noel,
Hows the turbo install coming? Did you add some washers to the engine mount rubbers to give some clearance? And the hose alignment? Looked thru your pictures, very nice build. I see u doubled up on the axel sleeve. Good idea. The only suggestion i could see is to reccomend installing the tracy obrien backing plates for the axel to brake caliper. You will be able to use 3 holes , better than the single tab, as some have snapped off. Keep at it! Thanks for the posts.
Users browsing this forum: No registered users and 58 guests
