rocker arm ball misalignment
Posted: Sun Apr 30, 2017 1:02 am
Hi all,
I looked around for a similar post but found nothing.
I have a turbo Aerovee and have adjusted the valves to the specs recommended by Sonex: 014 for exhaust and .008 in intake. I have noticed that after the last few flights that after adjusting the valves that the flat face of the swivel rotates around so that the flat face in now on the backside. This causes the gap to decrease and leaves the exhaust ports continuously open. This has happened twice to the same exhaust ports today. Observers were present to verify that I was not misconfigured, both times.
Has anyone had this experience before? And if so, what was the cause and solution? The last time I adjusted the valves, I reduced the gap on the exhaust side from .014 to .013 and I will fly it tomorrow to see if it repeats the problem. I will update tomorrow.
