Prop Hub Interference?
Posted: Mon Mar 13, 2017 2:09 pm
Hi All,
So my AeroVee is proceeding with two steps forward, one step back... :?
After tightening my case bolts I found the crankshaft had a portion of the rotation that was stiff. Nothing appeared to be knocking or hitting; but upon close inspection I found my prop hub rubbing against the engine case during a portion of each revolution. After disassembling the case I found metal filings between the forward bearing and the prop hub, confirming my suspicions.
I know some other folks have posted about clearance problems in this area - but for me the clearance between hub & case seems to follow the prop hub as it rotates: I can make a mark on the hub and follow it around the case. Wherever the prop hub mark is facing, that area tends to have the least clearance. And when the mark is in the ~10 o'clock to 1 o'clock positions it is physically rubbing on the case (and the gap on the underside of the hub is quite large). When the mark on the hub is facing 6 o'clock I have OK clearance all around.
This leads me to believe that the hub is out of round or is not on the crankshaft straight. Photos are here: https://flic.kr/s/aHskPzJwFG
I ordered the pre-assembled crankshaft from AeroConversions, so I've contacted support. But per some automated messages they've got limited availability this week.
Anyone here dealt with a similar issue?
--Noel
--Noel
