Piston Ring End Gap
Piston Ring End Gap
Postby XenosPilot » Sat Oct 22, 2016 6:18 pm
I just honed the cylinders on my Aerovee with 42 hours on it. It had low compression numbers on the rear cylinders during the annual inspection, so I took it apart to inspect. Most of it was certainly in the valves, which I lapped, but there were also vertical scratches on the cylinder walls. FYI, the engine sat for 3 years without running. Now to the point...When I checked the ring end gaps after honing, the top compression ring was between 0.012" and 0.022" like it should be. I then measured a few of the 2nd compression rings and found them to be about 0.006".
My question is, what do I do to resolve this? Do I order different rings? Do I just file the rings until the gap is okay? Has anyone dealt with this before?
Stephen Layton
Stephen Layton
Xenos, Aerovee, Aeroinjector, 100LL, MGL Enigma panel
Prefer motorless flying...soaring!
Hobbs, NM
XenosPilot
Re: Piston Ring End Gap
Postby Bryan Cotton » Sat Oct 22, 2016 8:50 pm
Stephen,
That is our next step. On other engines I filed the rings to make the end gap requirements.
Postby XenosPilot » Mon Oct 24, 2016 10:17 am
I had never done this before, but I was able to use a file and get the rings to spec. yesterday in just a few minutes each. Thanks for the reply!
Stephen Layton
Hobbs, NM
XenosPilot
Users browsing this forum: No registered users and 58 guests
