more AeroVee regulator discussion
Posted: Thu Aug 25, 2016 11:55 am
Greetings... just received a new regulator from Sonex and have a statement and a question:
- this is a Transpo/Kohler regulator KH4309 typically used on John Deere mowers, marine engines and several motorcycles (Ducati, among others). It is exactly the same regulator available online ( http://goo.gl/E0vyVU ) for $13.00+. So more expensive (by a factor of ~3) does not necessarily equate to higher quality, sometimes simply higher mark-up/profit margins.
- the wiring diagram in the manual seems to indicate that one of the AC terminals is tied to the B+ terminal. I can't locate a schematic for this regulator, not sure why that jumper is used, but if it is indeed used/needed, how are you guys tieing those terminals together?
Thanks!
Thanks!
