by wlarson861 » Tue Jun 21, 2016 1:25 am
I changed to the top cooler before the turbo upgrade. I ran a loop of AN-6 braided hose between the inlet and outlet ports on the oil cooler. When I did the upgrade the new oil pump eliminated the hose. The hose loop worked just fine for the several hours I ran with the top cooler. I made a tunnel into the rear baffle since i didn't want to buy more cowl seal and upset a well sealed top at the rear baffle. The temps were mostly the same and often a little cooler (oil temps) after the change, less than noticeable for the most part. I have the vertically split cowl so I had to remove the front flange to let the cowl fit and also had to file a small grove for the hinge. The instructions show that the whole top layer of cooling fins and top plate have no oil in them and can safely be removed. The mod is pretty easy and makes one less thing to remove at every oil change. After blowing a bottom cooler, I wish this was an option when I did the first build on the engine.
Bill Larson
N861SX
