Rocker arm shaft bolt torque
Postby surfly » Fri Apr 29, 2016 3:30 pm
The Aerovee manual states to torque the shaft end bolts to 25 foot pounds. I feel that this excessive. Any opinions??
Also the chapter on installing the rocker arm shaft assembly states in the beginning that the builder might have to rearrange shims etc. to establish the correct positioning of the rocker arm balls onto the end of the valve stem. I found this to be true and interesting to do. This is not hard and with a little bit of patience is easy to do.
Building On
Surfly
surfly
Postby Sonex1517 » Fri Apr 29, 2016 4:09 pm
I also had to rearrange shims. No big deal, part of the learning.
I would follow their directions to the letter. Torque values especially, but be sure you use the correct value, inch pounds or foot pounds as specified. At first I confused myself - until I re-read the instructions.
Chicagoland
Users browsing this forum: No registered users and 76 guests
