Compression ratio
Sun Mar 20, 2016 7:42 am
by Kitfox93eg
Before I set my compression ratio I wanted to know what some of you a running. I'm going to run the turbo and from I can gather it's to be set at 7 to 1. I'll be running avgas as I've been using that in my Kitfox since they started adding ethanol in auto fuel.
Ed
Re: Compression ratio
Sun Mar 20, 2016 9:58 am
by wlarson861
Check the manual but if you are going to run only avgas then the compression would be 8 to 1. I run auto fuel (alcohol free) so mine was set at 7 to 1 both normally aspirated and now as a turbo. The turbo has nothing to do with the compression but rather the detonation potential of the type of fuel.
