13brv3 wrote:I ordered the EXT680 version specifically to have it be the same size as the Odyssey, only because it gives a fallback plan if the EarthX ends up not being reliable. I plan to move the battery somewhere behind the firewall either way, just to keep it out of the heat and out of the way of the turbo installation.
mike.smith wrote:
Just something to consider: given the history of lithium batteries, do you want the battery on the "wrong" side of the firewall? And in close proximity to a fuel tank?
It's not ideal, but it's the fuel tank I'd rather move ;)
Seriously, these are a relatively safe variety of lithium, and they're electronically controlled, so the risk is probably minimal.
Cheers,
Rusty
mike.smith wrote:13brv3 wrote:I ordered the EXT680 version specifically to have it be the same size as the Odyssey, only because it gives a fallback plan if the EarthX ends up not being reliable. I plan to move the battery somewhere behind the firewall either way, just to keep it out of the heat and out of the way of the turbo installation.
LarryEWaiex121 wrote:I'm curious as to why, on their site, they indicate this battery will not work in a four sided battery box. The dimensions of an Odessey
PC625(my current battery at 13.1lbs.) and the XL680 are very similar.
