Onex107 wrote:Do any of you have a problem reading the oil dip stick? I can take the reading three times and it's different each time. I now take it out, to break the vacuum, put it back in, rotate it four of five times to get the oil level to settle down to the sump level, then take at least two readings. It will still measure higher on one side than the other. Have you changed the stick? Do you take it hot or cold? what level do you run? Are you returning the blow by oil to the sump? Do you use oil? If so how much an hour? I don't have this problem with my C-150 because the tube is much bigger in diameter.
vigilant104 wrote:I've found that a regular black zip tie (about 8" long and 1/4" wide) makes a good dipstick. It's flat, so there's plenty of surface area to permit easy observation of where the oil line is. It's stiff enough to stop when it hits the bottom of the oil pan. I put a nick in the edge to show me where "full" is.
Users browsing this forum: Dave Wolfe, Google Adsense [Bot] and 19 guests
