How do you seal your valve cover bolts
Postby kmacht » Tue Dec 15, 2015 4:48 pm
I have an issue with the aerovee that has been nagging me for a while now. What is everybody using to seal the bolts that hold the valve covers on? The holes in my valve cover are tapered. I swear that the original valve covers came with a tapered o-ring / plug that went under the bolt but I asked Sonex a while back and was told that it is just a normal o-ring. My original ones were toast after pulling the bolts so many times during the first 40 hours and every time I use an o-ring now it either gets chewed up or broken since I am trying to force a round o-ring into a tapered hole. I can't be the only one with this issue. I have been using some RTV along with the o-ring up to this point to make a seal but it creates a bit of a mess every time I want to pull the cover to adjust valves. Am I the only one with the issue? Did the valve covers change over the years?
Re: How do you seal your valve cover bolts
Postby Rynoth » Tue Dec 15, 2015 5:42 pm
Maybe the valve covers changed? In my Aerovee delivered late 2014 the recess for the bolts is flat (not tapered) and the O-rings (fitted between the bolt head and the outside of the valve cover) seem to be doing the trick to keep the oil in.
Postby mike.smith » Tue Dec 15, 2015 7:39 pm
Keith:
My covers are like yours. I bought some oversized black plumbing washers at the local hardware store. The kind that are very stiff, and not nearly as soft and pliable as o-rings. They also have a tapered face on one side. I never found any that were the right diameter inside and out, so I used over sized and drilled out the center hole to be just smaller than the bolts. I just tightened them down into the valve cover and eventually the oversized part just wore away and fell off, leaving the right size filling the cover's holes. I have not had to replace one in a year and a half, and they never leak. I'll look around and see if I still have some. If I do I can send you some, or at least take a photo so you can see what they look like.
Postby gammaxy » Tue Dec 15, 2015 10:16 pm
I'm interested in hearing more about Mike's solution.
My understanding is Sonex recommends the -203 o-ring size. Mine get torn up pretty quick. I bought 20 or so on Amazon and treat them as disposable, but I don't really like that some of the torn o-ring can end up inside the rocker cover. I found some thinner o-rings in a VW gasket set. I'm pretty sure they are supposed to be rocker stud seals. They seem to fit my valve cover bolts perfectly and compress just enough to form a seal, but not enough to become damaged. I've had them in and out several times with no damage.
I think they might be pretty close to -011 size, but might be as large as -109.
http://www.marcorubber.com/sizingchart.htm
Postby mike.smith » Tue Dec 15, 2015 10:41 pm
Here is what I used for the valve cover bolts (plumbing washers). I think this size is smaller than what I ended up using. You can see one face if beveled, and the other is flat. I up-drilled the hole for the bolt diameter (actually just a tad smaller). The outside was too large, but after tightening and un-tightening a bunch of times the outside extra just wore away and fell off, leaving the right size.
https://flic.kr/p/C4MxwU
Postby sonex569 » Wed Dec 16, 2015 10:03 am
What I found at AutoZone was Fell-Pro Gaskets (Fuel Injection O-Ring set) Pn-ES 70599. These fit the covers as good as the originals and do not leak.
Regards
Dick
569SX
sonex569
Postby Klimek » Wed Dec 16, 2015 10:29 am
Keith,
Keith is correct. The fuel injector O-ring has worked well for me.
I used, at first, an injector o-ring from an Audi / VW water cooled engine CIS fuel system. I measured the proper ring
from the kit (the largest in the kit) then just bought nitrile O-rings from then on. They usually last 3-4 cover removals
and never leak. I did add a stainless washer under the bolt head then the O-ring. They conform to the taper very well.
Have two long cross countries under my belt. Fayetteville, Ar. to Houston, Tx. and Fayetteville to Miami Cty. ( just south of
KC, Ks) Not a leak...
Good Luck.
Frank
ONEX 090
54 hours +
4.8 gph
Klimek
Postby rkurian » Wed Dec 16, 2015 1:34 pm
I replaced my valve covers with the stock black metal stamped ones and have never had any leakage problem when using the cork gaskets.
Ray Kurian
Sonex 612 (N115DM)
Plans Built
Trigear, Aerovee, Dual stick.
First flight 4/11/2015
rkurian
Users browsing this forum: Bing [Bot] and 50 guests
