rizzz wrote:I'm only up to my 8th flight now but on my 2.4L VW engine I'm getting between 35 and 40 PSI once the oil is up to temperature.
I get around 65PSI right after starting.
I've got an external oil filter and bottom mounted external oil cooler.
Are my numbers a bit lower than they should be?
Gripdana wrote:I have nearly 60 hours on my Aerovee. Using the recommended Valvoline VR1 20w 50 oil. I have had pressures in the mid to high 60's from day one with oil temps in the normal operating range at 3200 RPM.
