Greetings, AeroVee builders...
I haven't yet started my AeroVee, but I've have spun it up a few times via the starter motor. Today I decided to drain the oil for no particular reason, and as the oil started out into a large, clean salad bowl, I heard a distinct 'clink'. This small object was fished out of the oil.
- P1130790.JPG (408 KiB) Viewed 4394 times
- P1130789.JPG (430.28 KiB) Viewed 4394 times
- P1130786.JPG (416.88 KiB) Viewed 4394 times
- P1130792.JPG (503.4 KiB) Viewed 4394 times
It appears to be an aluminum solid rivet, badly set (it is just slightly bulged). I must assume that it fell out of some internal assembly, but w/o starting to disassemble my engine, I can't really figure out which. So I'm hoping that someone knows where it came from, or can examine their as yet unassembled parts for a clue. I'm leaning toward the sump screen assembly, which is easy enough to take out, but I'll wait for any response from the S.O.S. :) I'm having trouble imagining why *any* internal assembly would be riveted together! And no, I did NOT accidently drop it in! Thanks!
