Aerovee not charging
Posted: Sun Jun 28, 2015 3:01 pm
The battery is not charging. I have the ignition fixed and operating properly. Now my battery does not charge. The battery is an odyssey per the plans. It is about 10 months old. I found a ground to the engine block loose and repaired it. Then charged the battery and flew for an hour today at 2900 to 3100 rpm. There was a constant drain. I do not have a fuse on the charging circuit and checked all the wires for proper connection. I have good crimps and no broken wires. Could I have a voltage regulator that has gone bad? To be honest I did accidentally short the positive on the battery as I was hooking it back up a while back. But it did charge after that it was showing 14v on the EFIS. There is no noise coming from the back of the engine when I hand turn and I did all of the service bulletins and used the correct loctite and primer where noted.
