by Onex107 » Fri Jun 12, 2015 11:31 am
This may not apply, but, I just had a bad cylinder in the Onex after 60 hours.. Check the simple things first. I lost one cylinder when running on the secondary. The EGT nailed it down to #3. The secondary is the bottom plugs and I had just changed them all, so it had to be the wire. And it was. The OHMS ckeck was open. The end of the wire that I made up was bad. I had not been carefull enough when stripping the wire originally. The small inner core is covered with a black sheath and you have to be very carefull to not remove it when you strip the white insulation, and, the end of the wire must be located up to the hole in the crimped end so it is near or contats the end of the plug. When pulling the wire off the plug you can move the crimped end away from it's original position. Simple, but frustrating.
