by nwawingman » Sat Jun 20, 2015 12:09 am
I think I pulled my heads off of a well running AeroVee without really needing too.
The manual says to perform a leak-down test at Every annual and you should see between 60 and 80. I forgot that Bruce said to do this on a hot engine. :( Anyway. this is what I was seeing using an ATS Differential pressure tester on a cold engine after I set valves and torqued the heads. I had the intake manifolds off also. 1 -65lb. 2-4 ranged from 25-30 lb. I could hear noticeable air in both the intake and exhaust. Again this was on a cold engine and the spark plugs all looked good with know signs of issues on a well running AeroVee. It too bad that I forgot Bruce's comments before doing the test and called Bob and Charlie after I already pulled the heads off. I keep reminding myself, this why I like working on my own plane. I am always learning more about my aircraft and If something is done wrong, there is know one to blame but myself. From some more research I have done along with advice from Bob and Charlie, I will do my test like this next time.
This is just my thought going forward based on this experience, as I am clearly not an expert in this area. For now my heads are in the shop getting the valve cleaned and re-lapped. Now I can say II know what the insides of my heads and pistons look like with a 100 hrs on them anyway. :)
Step 1 - With a cold engine remove and check plug condition of all bottom spark plugs.
Step 2 Put anti-seize compound on plug treads and install with a snug fit. Not fully torqued.
Step 3 Run engine enough to get heads and cylinder to operating temp. Then let it cool enough that I can do test without burning myself.
Step 4 Remove bottom spark plugs and screw on standard single gauge compression testers for each spark plug opening and run the starter for 5 sec or so to get a good pressure reading. I read that all of your cylinders should be within 25% of each other. So take your highest pressure reading and multiply by .75 to see the low end pressure limit. (Example 125 X .75 = 94) for this example all cylinders should be within the 125 - 94 range and the closer they are together the better.
Step 5 if needed use my ATS Differential pressure tester to help locate where the issue may be.
Step 6 sleep on it and call Sonex or a few Sonex builder builders for ideas and thoughts before you take anything apart.
