Strange issue - engine stalls
PostPosted: Mon Jun 16, 2014 10:50 am
by floridasonex
Ok .. this one has me baffled.
Sonex Trigear
Aerovee with Aeroinjector
90 hrs on plane
After I land when I slow to walking speed and make a left u turn on the runway to backtaxi
the engine stalls for a moment .. then goes. Doesn't seem to do it in a tight right turn.
No problems in the air .. in the pattern .. or anyplace else. I have an outside air duct
to the carb area (not ram air) and it does it with that open or closed.
The fuel line is the braided stainless wrapped in insulation with the silver coating,
like you'd use on a firewall. Shield between it and the exhaust pipe. Wrapped
exhaust.
Any ideas?
RT
1579
Re: Strange issue - engine stalls
PostPosted: Tue Jun 17, 2014 3:05 pm
by kmwoody
RT,
My Aerovee, Aerocarb hesitates like you described when I make a slow left turn to stop to run-up before takeoff. It has done it since I purchased it at 90 hrs. and still does it at 228 hrs. It concerned me at first, but doesn't anymore. My engine has never hesitated on takeoff, except when I forget to push the mixture full rich.
Ken W
Sonex 959
PostPosted: Tue Jun 17, 2014 4:21 pm
by floridasonex
Ken ... are you using autogas? I am starting recently. Never had this with 100LL.
Roger
PostPosted: Wed Jun 18, 2014 4:16 pm
by kmwoody
Roger
I am using 100 exclusively now. I started with 100, went to a 100LL/93 auto mix, now I'm just going to stick with 100. It has hesitated on the left turn no matter which fuel I used and it happens just ocassionally. I figure it is because I lean very aggressively at idle.
Ken W
