mike.smith wrote:So the only thing we have not specifically checked are the P-leads. In not sure what to check or how. The P-lead wire runs from the mag, through firewall, and to the switch.
radfordc wrote:mike.smith wrote:So the only thing we have not specifically checked are the P-leads. In not sure what to check or how. The P-lead wire runs from the mag, through firewall, and to the switch.
Are you saying that you have one P lead wire going to a switch that controls both mags? If so that is a problem.
Each mag must have a separate P lead wire going to its own separate switch. Actually you can use a DPST switch...which is just two separate switches in one case.
sonex1374 wrote:Your problem may be with the large triggering magnet. If the magnet retainer bracket is loose, even a bit, the magnet will flex outward under higher RPM and close the 0.010" gap between the magnet and the magnatron unit. Once they strike each other, the shock to the magnet will destabilize it. The magnet might be slightly weakened, thus causing the roughness when running only on the mags, or it might be really messed up and the engine won't hardly run at all.
I would remove the magnet and retainer cover and inspect it for scuff marks or scratches, check to see how strong the magnetic force is (it should be "gorilla strong"!), and if there's any doubt replace it. Also check the magnatron units for signs of impact. They can take some abuse, but the heat of friction from a rubbing magnet cover will eventually break them down internally.
When you reassemble the magnet and cover, make sure that the screws are tight, and have locktite to really hold them in place.
Jeff Shultz
SonexN76ET wrote:.Mike,
I am no expert but I am sure that the problem is the shielded wire on the p leads. It is partially grounding the magnitrons causing the roughness.
Unlike other P leads referenced in homebuilders manuals calling for shielded wire, the P leads to the Aerovee magnitrons are not connected to the Aerovee when it is switched on (thus the upside down ignition switch called out in the manual). When you turn the switch off (which is really on , remember the upside down switch shown in the manual) it connects the p leads to the magnitron p lead and grounds the p lead, thus shutting down the magnitron. The shielded wire is likely partially grounding the magnitron causing the roughness. Again I am no expert, just trying to help. It appears the grounded shielding may be allowing the ground to "jump" to the highly charged magnitron the same way if you hold a negative wire close to the positive post on a battery. Good luck!
mike.smith wrote:radfordc wrote:mike.smith wrote:So the only thing we have not specifically checked are the P-leads. In not sure what to check or how. The P-lead wire runs from the mag, through firewall, and to the switch.
No, I'm just saying the TWO P-lead wires go from each mag to the individual poles of a DPST switch. I was just short-handing the response.
