Oil Cooler Structural Failure
Re: Oil Cooler Structural Failure
Postby SonexN76ET » Sat May 05, 2018 6:57 pm
Patrik,
I would recommend getting an oil pressure sender that corresponds with the settings on your MGL. I do not believe the readings you get with a sender that is different from your MGL will be linear. At least that was my experience when I tried a different sender when troubleshooting erroneous readings.
Jake
Sarasota, Florida
SonexN76ET
Postby lutorm » Sun May 06, 2018 2:50 am
I just changed the full-scale reading from 145 to 72 psi and it appears to read just half of what it did before. I don't see why the full-scale setting should affect linearity. (The resistance setting definitely will though, but as long as you actually set it to the correct value it should be fine.)
lutorm
Postby Sonex422 » Mon May 07, 2018 7:35 am
Get one of these test units to verify your oil pressure readings.
https://www.harborfreight.com/engine-oi ... 62621.html
This will give your peace of mind.
Detlev
SW Michigan
Sonex, first flight 2013
Standard Gear, Center Stick
Aerovee
I-Level 3AW driven dual I-Pad mini panel
Sonex422
Postby bvolcko38 » Sun Jul 08, 2018 9:37 am
Where is an OEM quality oil cooler available? Not a chineseium knock off.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Users browsing this forum: Google Adsense [Bot] and 43 guests
