Cotton AeroVee 0795
Re: Cotton AeroVee 0795
Postby Bryan Cotton » Fri Dec 02, 2016 12:52 pm
I agree with the last 2 posts. Those bolts are M8 X 1.25 right?
Postby bakfly » Fri Dec 02, 2016 6:53 pm
Bryan Cotton wrote:I came up with a solution for the pushrods. I put another shim under the rockers and the alignment was still good. Now I have a boatload of adjustment as the motor runs in. Adam now knows how to find TDC and adjust valves:
As a kid I learned good judgement to avoid stripping holes. How? Well, I stripped a bunch of holes, of course. Adam did his first one on the fuel pump blockoff plate. All the threads came out nicely like a spring on the bolt. We have a helicoil lesson in our future. I assume they have metric helicoils.
Just be careful,having another shim under the rockets brings the rockets and valve clearance adjusting screws higher up and there is a possibility they hit the rocket cover preventing the valves from closing, especially when the rocket cover gaskit is compressed a bit. This happen to me and I lost compression on 3 cylinders.
Peter,
Sonex 19-8464, Aerovee 2.1
Flown 140hrs
bakfly
Postby Bryan Cotton » Fri Dec 02, 2016 9:18 pm
Thanks Peter, I will look out for that.
Postby Bryan Cotton » Sat Dec 03, 2016 11:08 pm
Grinding down the flange of the oil cooler:
Next we had to bolt it to the case. No stripped threads tonight.
Motor on bench so we can put on the rear main seal, shims and flywheel.
Postby Bryan Cotton » Tue Dec 06, 2016 11:14 pm
I didn't read far enough ahead to buy a VW oil seal installation tool. So, we made one. First, a little holesaw to make room for the crank pins. Next, a medium one to make a notch. Finally a big one to set the OD of the tool:
The middle holesaw is taped to the plywood while seated in the notch.
Now I just need Locktite 272 and a 300 ft-lb torque wrench.
Postby rizzz » Wed Dec 07, 2016 5:11 am
Bryan Cotton wrote:Now I just need Locktite 272 and a 300 ft-lb torque wrench.
Hi Brian,
I doubt many of us have actually used a 300ft-lb torque wrench for this job. They are very expensive.
If you put an extension on a normal wrench/spanner with the correct socket attached, you can calculate how far from the center of the socket you have to push down with your full body weight to achieve the required torque, here's how I did mine:
http://mykitlog.com/users/display_log.p ... 484&row=57
I believe that's what most people do.
Postby Bryan Cotton » Wed Dec 07, 2016 8:05 am
Thanks Michael. I'll weigh Adam since I don't want to go near the scale.
Postby sonexsteve » Wed Dec 07, 2016 3:22 pm
I've just done this job a few weeks ago, getting hold of the Loctite 272 was a major hassle, eventually found a substitute Kerry approved of. As for the torquing up to 227 ft/lbs I found an air powered impact wrench, sold for doing up vehicle wheel nuts, in a local technical chain store, that on its 'high' setting was rated at 300 ft/lbs - so I just used that. Can't say whether it leaks or not, I've yet to run the engine.
sonexsteve
Postby Bryan Cotton » Tue Dec 13, 2016 11:01 pm
The fine art of RTV / caulk application:
Torqued!
Postby Bryan Cotton » Fri Dec 16, 2016 8:06 am
We got the magnatrons, accessory plate, and intake manifolds installed last night. Magnatrons are gapped and torqued.
