BRS wrote:When I did the cold air intake on the R2300 using a Rotec MKII carb, Rotec cautioned about elbos near the carb. There were none but but I did go ahead and make a flow straightener to dampen any intake air swirl. Perhaps something like this might be helpful.
mike.smith wrote:You need to get a good reading on the CHT. That's all the matters, really. If the CHT is in line with the others, and within the proper range, then there is likely nothing wrong with the cylinder, so it would be a sensor or display issue with the EGT.
WaiexB22 wrote:I read through this and I have a few thoughts/considerations:
Good luck!
