Cotton AeroVee 0795
Re: Cotton AeroVee 0795
Postby Bryan Cotton » Fri Nov 18, 2016 12:15 am
Chris,
We did hear it, but convinced ourselves the lifters were slipping back and forth in their bores. We'll watch the video. The motor comes apart fast! Got the top end off.
Postby Bryan Cotton » Fri Nov 18, 2016 10:00 pm
Case split, cleaned, and fresh permatex going on:
Clothespins in backward to hold the lifters, with a piece of welding rod holding the clothespins:
Torquing case haves again:
We are nearly back on track.
Postby Bryan Cotton » Sat Nov 19, 2016 8:43 pm
Whoops:
Adam was having an off day - first he spilled my cup of coffee and then he forgot the super tin. On the bright side, we have potential to be a Formula Vee pit crew!
Postby Brett » Sat Nov 19, 2016 10:19 pm
Oh no,,,,, not the coffee :)
Looking good but.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby Area 51% » Tue Nov 22, 2016 10:10 am
I think I see the problem...............You don't have your Waiex shirt on.
Postby Bryan Cotton » Tue Nov 22, 2016 10:34 am
Ha - just ordered up two fresh Waiex shirts, Randy. They are on sale, $9.99 at www.eaa.org. Adam has adopted my old EAA533 shirt for the dirty jobs. The reason it is partly bleached out is because I was doing a plumbing job, and had to remove some pipe. My wife had thoughtfully put about 10 gallons of liquid plumber down the sink before calling me about the job. When the pipe cracked, it all dumped on me and I had to beat it to the shower to get that stuff off of me. It was actually sort of scary.
Postby Area 51% » Tue Nov 22, 2016 10:58 am
Saw the bleach spots on the shirt in the picture.........Thought you got hold of my laundry some how.
Got the engine mount on and gear legs attached. Nice to be able to roll the beast out of the way. Still fighting with the fuel tank though.
Postby Bryan Cotton » Tue Nov 22, 2016 11:06 pm
We had to grind the case with the dremel a bit to fit the oil pan thing on:
Ultimately we triumphed. Good dremel practice for Adam.
We got one drive bushing 98% on and then snapped my one bolt. I'll have to buy some grade 8 bolts for this task. Also I had to tweak the oil pickup into place for the screen to go on.
With the top mounted oil cooler do I want a different pump? Seems like running a loop of tube is a pain. We have the maxi-flow pump.
Postby wlarson861 » Wed Nov 23, 2016 1:06 am
Knowing I would eventually upgrade to the turbo, I changed to the top mounted oil cooler. My pump that came with the original engine kit had the ports for the bottom mount oil cooler. When I asked Kerry he said to run a loop of braided hose, otherwise I would end up with three different oil pumps. I made up a bypass loop of hose and ran several flight hours that way until I decided to go turbo. The only thing to watch out for is that you make it long enough to push out of the way of the cowl. I also wrapped the braid with silicone tape to keep the braided stainless steel from wearing the fiberglass of the cowl. The price for a new straight pump is $81.50, the hose less than $10.
Bill Larson
N861SX
wlarson861
Postby Bryan Cotton » Wed Nov 23, 2016 10:58 am
Do those ports plumb to the turbo if I go that route later?
cron
