GraemeSmith wrote:Notwithstanding our modest fuel flow needs and a lot of folks indicating success with red cubes.
The Gold Cube is indicated for Gravity Carbureted and Injected Engines
The Red Cube for engines supported by a fuel pump.
As they are both the same price at Aircraft Spruce at this time - Go with the Gold! :-)
NWade wrote:
Graeme - In the past, Sonex builders found that the Red cube tended to work better than the gold, even though the gold is what is indicated as the “proper” one (for carb’ed gravity-fed engines).
It seems backwards, but there was a consensus around this as of a few years ago.
My red cube has worked fine with my AeroVee Turbo & Aeroinjector over the last 4 years of limited ground-running (dear god my build has taken forever to finish); hopefully I’ll be able to use it in the air very soon!
—Noel
Thermalflyer wrote:I have the gold on a OneX. The RDAC- XF does not have a FF signal input. I have the red on the 5 volt and the white on the FF1, Ground is at the engine block. I do not get any reading on the MGL Light.
Since there is no signal port I am not able to install the resistor to comply with the setup shown on the MGL install sheet. Any help?
Users browsing this forum: Bing [Bot] and 23 guests
