Camguard
Re: Camguard
Postby Bryan Cotton » Fri Dec 11, 2020 11:32 am
I just ordered my first jug of Valvoline VR1 20W50 from Amazon. It is funny how many of the reviews say "this is perfect for my classic VW bug!"
Re: Camguard
Postby GraemeSmith » Fri Dec 11, 2020 5:07 pm
I actually did have a follow up out to Ed along the lines of:
"So what oil would YOU use in the VW Type III engine as we are using it in the aviation environment"
His interesting response was:
Ed Kollin wrote:I would probably use a 15W-40 diesel oil like Shell Rotella
Don't think I'll try that yet!
He did say that the Valvoline or Brad-Penn fortified with Camguard - would improve them to a point he would be more comfortable.
To the point about Aero Shell Sport Plus 4 replacing a bike oil in Rotax engines - he was very enthusiastic. He didn't have much good to say about the previous bike oil!
Re: Camguard
Postby bvolcko38 » Fri Dec 11, 2020 5:10 pm
My thoughts exactly. Diesel oil is high in zinc and detergents.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: Camguard
Postby WesRagle » Sat Dec 12, 2020 10:45 am
Lots of advice when it comes to engine oil :-)
https://www.youtube.com/watch?v=BvN83Xb2xy8
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Camguard
Postby Rofomoto » Sat Dec 12, 2020 12:15 pm
Covair uses Rotella 15-40. With ZDDP addictive exclusively. Billy
1735
Longassproject
Rofomoto
Re: Camguard
Postby GraemeSmith » Fri Mar 12, 2021 7:10 pm
First results after 25 hours on Valvoline VR 1 with Automotive CamGuard
ALL metals are down 25%-30% on the oil analysis @ 391 hours TT
Compressions measured at the end of 25 hours on Camguard 78/78/78/78 (From 72/74/78/76 - 25 hours before @ 366 hours)
Disclosure - Ed Kollin of ASEL Camguard is assisting with advice and 4 free samples to be used over the 100 hours.
Re: Camguard
Postby BRS » Sat Mar 13, 2021 11:34 am
Graeme,
What fuel are you using? As mentioned earlier (about TCP) lead from 100LL likes to settle out of most automotive oils (is that true with the VR1?). I remember running a rotax 914 where lead settling was noticeable. Nice thing for rotax is that the remote oil sump is easy to open up and clean out. In my Lyc (sportsman) I run Phillips XC and 100LL. But in the sonex (still under renovation) I've not yet decided what I'll run in the revmaster. I'm not a fan of ethanol and 'clear' is not much cheaper than 100LL.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: Camguard
Postby GraemeSmith » Sun Mar 14, 2021 3:21 am
BRS wrote:Graeme,
100LL - the only way I can get the octane required around here for the 8:1 compression my builder set up.
I run Decalin TCP in the fuel to try and get as much lead out the exhaust as possible. The plugs are whistle clean at 100 hours when I chuck them anyways as they are cheap enough.
I use mineral based VR1 - not the synthetic based - so it doesn't tend to sludge in the engine. In fact from past experience. Synthetic and 100LL is a passage killing sludgeathon. Ask Mobil if you were around in the day when they tried it and then paid for a lot of engine rebuilds.
I removed the "in sump" oil screen and have a Petersen High Flow 60 micron filter with cleanable element on the front of the engine below the oil cooler air scoop. The holder has some pretty "thick" goo in it towards 25 hours - but it is not gray sludge yet. I vacuum the hot oil out from the low point of the engine sump where I fitted a quick drain so I don't have to keep dropping the oil cooler air scoop. A pint of mineral spirit into the empty engine and vacuum that out. Then Button up and refill. So I only drop the sump every 100 hours and it's clean.
One thing that Ed Kollin mentioned was Camguard's ability to help get lead sludge out. It doesn't show in my oil numbers. I suspect the Decalin has been doing it's job there. So jury still out on that one.
Re: Camguard
Postby GraemeSmith » Thu Jul 08, 2021 6:51 pm
So just to follow up on another oil report just in, where the metals are down to tiny levels. Blackstone's summary is:
Blackstone Labs wrote:The last sample looked uncharacteristically good, with most metals reading at some of their lowest levels on the page. That makes for a tough act to follow because metals can't always read at their lowest levels, otherwise at some point the engine would have to start putting metals back on the parts. So this report looks fine. The wear levels are certainly out of line low compared to what we've generally come to expect from this particular engine. No contamination was found. Looks fine from here.
This is in line with Ed Kollins of ASEL's prediction that after a couple of oil changes with Camguard metals would drop significantly.
Fingers crossed for the next report.
Re: Camguard
Postby n502pd » Fri Jul 16, 2021 12:37 pm
Has anyone who has been using VR-1 20/50 non synth oil in their engine encountered sludge build up? And has anyone had any adverse effects of using additive with high zinc with the VR-1, or with the Brad Penn Penn Grade 1 racing oil? Lastly, is the VR-1 oil causing sludge, where the Brad Penn oil dosent, while using 100LL? Thanks for any insight/info!
Joe
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
