Cabin Heat for Aerovee
Re: Cabin Heat for Aerovee
Postby marsolgp » Sun Dec 08, 2019 10:49 am
I used 2 Aircraft Spruce heat muffs in series..... worked great. You are right about the 1.5" diameter so I just used a couple 'wraps' of DEI exhaust wrap to make up the difference in diameters. It actually does two things: takes up the space between muff and exhaust header and prevents wear.
And agree 100% with Jeff, installing boots on aileron pushrods helps immensely...
By the way, I have two of the heat muffs for sale. $100 each plus shipping. PM or email for photos or info.
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
marsolgp
Postby XenosN42 » Sun Dec 08, 2019 11:03 am
mike.smith wrote:
pappas wrote:I called Dave at custom Welding Products in Las Vegas. He makes a line of heat muffs that he markets through Aircraft Spruce. The aerovee exhaust pipes are aviation non-standard so I asked if he could make up a muff for the turbo on my Waiex B. Sure enough, it was in the mailbox a week later.
I measured today, and it looks like 8" is the max length that will fit on the #4 exhaust pipe. Is that the length you have?
On the A/C Spruce web site I don't see any way to ask for the custom 1-3/8" diameter end caps. They only show the smallest openings at 1.5". How did you get the right diameter?
Hi Mike,
I also spoke to Dave at custom Welding. He told me to email him when I ordered the exhaust muffs and tell him: when I ordered, who I ordered from, and the exact diameter and length needed. He said he'd match up my name with the order he gets from ACS to make sure I get what I need.
-- Michael
OneX N169XE
XenosN42
Postby XenosN42 » Sun Dec 08, 2019 11:45 am
Hi Mike,
I'm currently considering installing those heat muffs, but if you are going to install them I'll wait and get your opinion on their effectiveness first. I know you've try other versions in the past so your observations will be highly respected.
-- Michael
OneX N169XE
XenosN42
Postby pappas » Mon Dec 09, 2019 7:45 pm
I measured the CWP heat muff that I installed on the #4 exhaust pipe. It is exactly 7 3/4 inches long and the endcaps are sized exactly for the Sonex exhaust pipe. ( I sent the diameter of the pipe to CWP with the order and he cut them to fit.)
If I made the heat muff any longer it would have come into contact with one of the pushrod tubes on #4. However, I installed spring-loaded 2 piece tubes at about 12 hours. If you have the standard tubes a slightly longer heat muff may not have the same clearance issue.
In any case, I get great heat from this thing. It is the same heat muff I installed on my RV-8 but that was sized for the IO-360 and 4 into 1 exhaust.
Lou Pappas
Waiex B Turbo...and others
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby mike.smith » Tue Dec 10, 2019 10:07 pm
Thanks, Lou. I may just have to give it a try.
BTW, I ran the spring loaded tubes for a while, but they leaked more than the standard pushrod tubes, at least for me, so I put the stock ones back on.
Users browsing this forum: autopro and 61 guests
