Timwaiex0146 wrote:Hi ! I just took my aerovee off the mounts after reading this thread. It has been on the mounts for about two years and has yet run . Sure enough , the holes were all oval , just from sitting there patiently. I purchased a set of the poly bushing, but they are different from the rubber mounts. They fit in the mount holes but have no shoulder like the factory rubber jobs , also when pulled tight the tube the bolts go through sits about 1/8" proud of the bushings so you need about fourfender washers to fit over the tube so you can tighten the bushings sufficiently . Does this seem right ? Any advice would be great fully appreciated. Tim 0146
