bvolcko38 wrote:Why did you remove your oil filter?
pfhoeycfi wrote:My aerovee Turbo has been running good, making 40+ inches easily, has a tach time of about 10 hours. So far only minor oil leaks, however I pulled the intake elbows off to re torque the heads and found that the inner surfaces of both intake fittings are wet with oil. Has anyone else seen this? I'm going to perform a leak down test. Vw normal? Rings? Valve stems? Turbo? High oil pressure? Any thoughts on oil in the intake?
Bryan Cotton wrote:Got my rockers back on, valves adjusted, and here is my drain:
pappas wrote:On my Turbo Waiex B, I found a lot of black, sooty residue with a little oily dampness in the rubber intake elbows and intake manifolds. It was always there throughout the 150 hours I had the craft. I never found a good reason for it and couldn't figure out if it was a source of concern or not. It seems to me this area should be dry and clean all the time. Who else has seen this, any ideas?
