by gammaxy » Sun Sep 23, 2018 4:55 pm
Dennis,
That's a lot to go wrong in the same flight, I'd assume all problems are somehow related. In this case, I'd expect that whatever was involved in the alternator failure removed the secondary ignition from the circuit.
Is the entire secondary not working? Over time, I've had 3 bad coils, but I've never lost more than 2 cylinders on the secondary at a time. The first two prevented the plugs in two cylinders from firing. The final failure somehow only prevented one plug from firing. For checking the coils, measure the resistance between the 12v terminals on the top to see if it matches the labeled 3 ohms. Then measure the resistance between the high voltage terminals--it should be tens of thousands of ohms, but I forget the exact value. Then measure between the high voltage and low voltage terminals. I believe this should be an open circuit. One my most recent failure, it was around 1MOhm.
For testing the triggers, it's probably best to just attempt to use them as intended and see if they output 12v and drop to 0 whenever a magnet moves by. I did this on my workbench, but if you're careful it can probably be done on the airplane. I've never had a trigger failure so tend to be suspicious of the coils.
