Bryan Cotton wrote:Had some email exchange with Mark Schiable. He did not recommend running both A and B model outlets together. I bought a set of B outlets from Sonex but am holding off.
All -
For those not on the Facebook page, I performed the first flight of my Legacy Sonex with an AeroVee Turbo & "B-model" side exits (on a Universal cowling with no exhaust tunnels) back in mid-May. I found that the engine did not cool
AT ALL with just the side exits once I went to takeoff power. I have since added a 13" x 5" opening in the bottom cowling at the rear with a ~1.5" deflector (angled downward from horizontal by 30 degrees). I hate the idea of the extra drag of the deflector, but this bottom exit has taken my CHTs from ~450 down to ~380-390 as long as I keep the MAP below 31" after about 90 seconds of takeoff power (40" MAP). This is still not ideal, but way better! And that comes after I tried redoing my baffle seals and other tweaks to ensure I was getting good air to the upper plenum.
Per suggestions from Sonex I'm going to try taping over the side exits on an upcoming flight to see how that changes lower cowling airflow. I may also temporarily mount deflectors to the front of the side exits to see how that changes drag & cooling.
I am still dealing with some pretty insane temps in the rear of the engine bay. Its causing some vapor-lock issues on landing & taxi after flight (even with firesleeved fuel line and aluminized fiberglass heat shielding over the fuel flow sensor). The AeroInjector itself is skin-blisteringly hot after flight and I'm worried the heat is going to kill the firewall-mounted items like my engine monitor RDAC, voltage regulator, etc. I am debating whether to mount a NACA scoop on the side of the lower cowling with a blast tube generally directing air along the firewall; or whether I should punch a small hole in the rear engine baffle and use a short bit of SCAT/SCEET tubing to achieve the same effect. Either one potentially disrupts the pressure differential between the upper plenum and lower plenum; but I don't see a better way to get more airflow to the firewall-mounted items and keep that area cooler. The engine bay with the Turbo is just tight and that area experiences low airflow plus a lot of radiant heat due to the turbo (even with the SS shield looped around it).
Bryan - Regarding oil pressures: If you look through my older posts you'll find an epic one about my oil cooler blowing out during early ground runs. A lot of the oil pressure sensors top out at 80-100 psi so if you see those readings beware that you _could_ actually be way higher than that!! When mine blew out (probably around 150 psi even though it only read 90 on the gauge), the pressure-relief plunger had gotten stuck at the very top of its travel. During assembly I could slide it smoothly in its bore on the bench, and thought it was hitting the end of its travel. But in running conditions it was able to push up a little further and get wedged.
So make absolutely certain when you polish the plunger that it really is making it to the end of its travel in the bore without any impediment. I polished the plunger and then also wrapped some fine-grit sandpaper around an appropriately-sized dowel and did a light bit of polishing/sanding to the bore (and then carefully rinsed it out *thoroughly* with 90% isopropyl alcohol to ensure I wasn't putting a bunch of metal grit into the oil system). Now with Penngrade 15W-40 I see ~45-55psi in flight and ~10-20 psi on the ground.
Hope this info helps,
--Noel
Sonex #1339
