Verifying the AeroVee Secondary Ignition Timing
Re: Verifying the AeroVee Secondary Ignition Timing
Postby Bryan Cotton » Mon Nov 15, 2021 7:46 pm
WesRagle wrote:Hi Guys,
Question: Has anyone tied their airplane down and checked the secondary ignition timing, with a timing light, as RPM was varied over a wide range? I seem to remember that there was a significant shift with RPM.
Wes
I did. No change. It is fixed timing. I didn't go to max RPM, too scary.
Postby Scott Todd » Mon Nov 15, 2021 10:12 pm
That's a great picture. Its about where my lines are. We found we liked the adjustment feature. It compensated for the lines not being accurate. From adjustment, to shutdown, to changing plug wires, to re-starting, all happens in less than a minute once you get the hang of it. Last time we worked on it, we did three adjustments and the whole process was about 5 minutes. Best $30 spent on the entire project!
Scott Todd
Postby Rynoth » Tue Nov 16, 2021 12:28 am
Thanks for the replies! That helps me understand how the timing light setup works. I do have a question as someone who has done 99.9% of my work on the plane solo... is it conceivable to setup a recording video camera focused/zoomed in on the timing mark location and do the ground run alone? And/or, has anyone taken video of the timing light test while in progress to determine whether a camera provides the same visual insight to the state of the timing via the timing light as eyeballs do?
Postby Bryan Cotton » Tue Nov 16, 2021 6:18 am
Ryan,
We had considered using the GoPro and watching it on the phone in the cockpit. Seems like it would work.
Postby Area 51% » Tue Nov 16, 2021 8:23 am
On your father's Ford, Chevy, or Dodge, the number one spark plug wire was necessarily used due to the single spark per 2 revolutions and the factory location of the timing marks on the balancer.
If you set a pointer to coincide with the #1 cylinder on our Aerovees, #3 will work just as good. 2 and 4 also play well together thanks to the wasted spark set-up. Adding one thing more, if you also highlight a flywheel tooth 180 degrees (44 teeth I think) from #1-3, you can use any wire you choose.
Postby Scott Todd » Tue Nov 16, 2021 9:15 am
You should definitely have a friend help for safety.
Scott Todd
Postby Spaceman » Sun Dec 05, 2021 2:35 pm
Howdy Gents,
What kind of RPM drop do you guys get during a run-up as you switch between the two ignitions? Mine seemed high so I got a friend to help me check the secondary timing with a timing light, and it looks right to me! However, my RPM drop seems to be about 250 on primary only, and 200 on secondary only, compared to both. Does that make sense?
Here's me checking the timing. I set the flywheel just like the picture in the manual depicts for checking the static timing, and then just made two silver sharpie marks on the left side where I could check it with the light.
Here's a quick run-up check (both, then #2 off, then both, then #1 off, then both):
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby WesRagle » Sun Dec 05, 2021 3:06 pm
Hi Chris,
Sorry, I can't answer your question but I noticed that your airspeed indication is varying with RPM. Where did you mount your pitot?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Spaceman » Sun Dec 05, 2021 3:20 pm
In the normal spot on the right wing... Yeah I've noticed that too, I'm interested to see how it behaves in flight haha
Chris Paegelow
Spaceman
Postby XenosN42 » Sun Dec 05, 2021 5:10 pm
Spaceman wrote:In the normal spot on the right wing... Yeah I've noticed that too, I'm interested to see how it behaves in flight haha
At those RPMs your airspeed should be a steady 0. As a test run the engine just as you did before but with the pitot covered.
-- Michael
OneX N169XE
XenosN42
