Spaceman wrote:ALSO, do you guys think sending cool air to the AeroInjector takes anything away from it's inherent icing resistance?
This is a valid concern. Think fuel injected IFR certificated aircraft. Icing over of the EXTERNAL air filter while in IMC. Most of those setups include a sprung plate in the air induction side inside the warm cowl that will open and provide unfiltered air in the event that the air filter ices over.
For non-injected the concern is the temperature drop in the carb venturi caused by accelerated air and vaporizing fuel. The carb will ice up if the humidity is high enough to allow moisture in the atmosphere to freeze. Most commonly on warm and wet summer days - rather than cold and dry atmosphere days.
So my method of directing cold air from outside across the air filter is a sort of blend of the two situations. It might be possible to direct wet air onto the filter which might just freeze if the air was moving fast enough. Though the actual fuel (and temperature drop) is downstream inside the induction tubes and after the filter. And those tubes are well warmed by the waste heat of the engine - by conduction if nothing else).
That said - my bird is VFR only - so no plans to fly in 100% humidity (ie in a cloud). Or high enough in a cloud where freezing might be an issue - and I think the wings would be a bigger issue first. That situation - I think there would be 100% valid concern.
Which leaves the possibility of a 99% humid summer day, VFR at a decent altitude. Ice hasn't happened yet - but you know what? I have a small remote temperature probe. I'm going to stick some instrumentation on it and see the rest of the story.
