Sonex1517 wrote:My GRT Mini shows an almost exact match to my TinyTach at idle on the ground. I’m using the AVC1 now, and once our insane Chicagoland weather settles down I will report back from a flight.
Sonex1517 wrote:Brief, preliminary update. The RPM does not work with the regulator as far as I can tell.
I’m two test flights in after reinstalling the Jabiru 3300. First flight, after three minutes of good reading, the RPMs began to fluctuate and then dropped to zero.
I removed the RPM connection for the second flight (I have a TinyTach) and the regulator does not seem to be charging my battery. It did not appear to be doing so on my first test flight either.
So unfortunately at this point, I’m going back to the original voltage regulator and going to contact the manufacturer of the new one to see if I did something stupid.
