Aerovee Turbo and TCP fuel additive
Re: Aerovee Turbo and TCP fuel additive
Postby bvolcko38 » Fri Jan 01, 2021 11:28 am
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby tx_swordguy » Fri Jan 01, 2021 1:26 pm
Have you tried Decalin ? It is designed to scavenge lead and what I use when I can't get the auto gas. I have no idea what if anything it might do to the turbo
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Postby GraemeSmith » Fri Jan 01, 2021 2:52 pm
Decalin is TCP - Just in a buffered solution with an easy to use dispenser. Same active chemistry as the brand "TCP"
Postby tx_swordguy » Fri Jan 01, 2021 3:14 pm
That may be but the TCP in TCP is 10 times higher in concentration than it is in decalin. TCP also has toluene and other chemicals that may play a part in why it is causing problems with the turbo. What ever the case, not using the TCP seems to be helping the issues with a stuck turbo.
Mark Whiddon
T25 Aero Estates
Sonex N889AP
tx_swordguy
Postby WannaFly » Mon Jan 04, 2021 9:05 pm
My turbo seized because of rust. sonex suggested trying STABLE FOGGER. So I added a port on my exhuast aimed right at the vanes. I"m at 60 hours now and have forgotten to use the fogger with no problems...
here is my email from
Mark Schaible
General Manager
Sonex Aircraft, LLC
We believe it’s more about humidity and surface rust on the cast iron housing that occurs when a newer turbo sits around for long stretches of time without running to burn-off the moisture. If the turbo is run/flown more often, it seems to be less of a problem. This is actually a service bulletin for turbocharged Continental engines dating back to 1971, and for Tornado Alley Turbines aircraft engine conversions:
http://www.tcmlink.com/pdf2/M71-21.pdf
http://www.taturbo.com/TAT%20SI15-02%20 ... turbos.pdf
We make reference to the above service bulletins in our AeroVee Turbo service bulletin ACV-SB-091616-1B: http://www.aeroconversions.com/support/aerovee_sb.html
Your turbo has no damage to the bearings or other internal components.
Regards,
-Mark
Mark Schaible
General Manager
Sonex Aircraft, LLC
Onex Turbo Aerovee first flight June 3 2019!!
RV6 in progress
Rans S14
Vector 627
100 hours 172
last flew 9/28/2000
WannaFly
