jjbardell wrote:It looks like you have an Earthx battery holder. If that's the case, it appears you have the wrong voltage regulator. It's hard to see in the pic.
jjbardell wrote:Noel,
I have the discovery lite EFIS. The AHARS unit has a tendency to tumble if I am running a higher load on the electrical system. It is believed that my issue is due to the voltage regulator. I talked to Matt at MGL who thinks that is the issue (spikes or drops in voltage will cause a digital gyro to tumble). We added a capacitor to address the spikes. It helped but not a 100% reliable still. I talked to Sonex and I learned they now have a new voltage regulator (not sure how new...just new to me), that puts more volts into the EarthX batteries.
The Earthx is a drop in replacement battery and I love mine. But if I am loading up the system, the voltage will drop slightly (as noted on my EFIS, with a tumbled gyro to follow). Once the voltage comes back up, then the horizon stabilizes (usually a second or two). Just long enough to disengage the A/P.
I have the new regulator installed, just haven't gone flying long enough to confirm it solved the issue. I have had no issues on my last 3 flights, but I want a long x-cntry with AP runnings, ADSB loading targets while running landing lights and transferring fuel. That will my final test before I can confirm my issue is resolved. My local A&P is fairly confident the issue is solved.
