jwd3ca wrote:Installed new regulator. No joy. STILL seeing 12.3 @ 2000 rpm. Should be over 14 :( I have a dedicated case ground, so it's not a grounding issue. Guess I better re-measure AC from stator, but it was over 40VAC previously, not holding my breath on that. GRT EIS measures bus voltage, has no relevant settings that I am aware of...
daleandee wrote:Hate to disagree with the others but you do have a problem. A fully charged 12 volt battery should read 12.6-12.8 volts before engine start. 12.3 volts shows the battery to be ~ 60% charged.
Users browsing this forum: No registered users and 86 guests
