by lgsievila » Tue Jul 12, 2016 10:32 pm
CAMit Engines have an inhibitor system available-below is copied from their website. I have one and it works as advertised
A hand-operated pump inside the cabin selectively sprays neat clean engine oil into the intake port during shutdown. The effect is similar to using an oil can to spray oil onto the top of the intake valve just prior to and during the transition from idle to zero RPM. The oil is dispersed in a radial pattern to coat the bore. As the oil is in a stream rather than ‘fogged’, there is less oil required; the large oil droplets attach to the hot surfaces without burning.
The pump displaces approx. 3cc – just enough oil to do the job, but an amount small enough that no noticeable smoke is created on subsequent start-ups.
Two pumps of the handle before and one during shutdown is all that is required for short term protection. For longer term protection, simply cool the engine CHT/valves to 50°C, restart the engine momentarily and inhibit immediately. The lower temperature ensures the maximum amount of residual oil remains.
The oil reservoir for the pump is part of the dipstick housing, allowing easy access and checking during daily pre-flight checks. Included in the system is a CAE dipstick.
The unit can be fitted directly to a new or overhauled CAE engine, as all CAE heads are already modified to accommodate the system. With some simple modifications (tools provided) to the heads to accommodate the oil jets, the inhibitor system can also be fitted to older 2200 & 3300 engines.
The inhibitor system comes with instructions to be easily fitted and eliminates the concern associated with leaving an engine laid up due to infrequent use. The inhibiting system can be used selectively, and without the removal or disconnection of any part of the aircraft.
Currently only available for EXPERIMENTAL installations.
Please contact us here for a price and with your shipping address, we will be able to supply the costing and time frame for shipping.
Onex33
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
