LarryEWaiex121 wrote:Ryan,
I was on the Earth X site and it makes reference to the EXT680 fitting into battery boxes that previously held PC680 battery. I reread the reference to 4 sided battery boxes and now believe it will work if I'm reading the information correctly.
I'm still uncertain as to the operating temperatures listed in the specs. Seems the operating range is too low to be under cowl? More investigation necessary.
Larry
Ercoupechris wrote:Seems like a much better value with similar weights and capacities for pennies on the dollar... Tell me where I'm wrong? I know its Lithium Iron which is different but I would like to know some opinions
4. Designed and engineered with a completely redundant battery management system (BMS) to protect your battery from over discharge, over charge, built in cell balancing, short circuit protection, and excessive cranking protection in addition to the integrated cell balancing technology. We are the only manufacturer that has this amount of protection.
GordonTurner wrote:But, as you have read, two things. Deep cycle will kill them (Earth-X circuitry protects their batteries from this), and in the deep cycle mode (powering stuff after the alternator fails) you don't get very much.
Users browsing this forum: Dave Wolfe, petep and 24 guests
