With regard to the method used by Aerovee, this type of pump cover was developed some years ago for the 'kiddie trade,' allowing youngsters to install an oil filter (and external cooler, if desired) without having to do any machine work on the crankcase. The method was never used on any professionally built engines that I know of for four pretty good reasons: The oil passages in the pump cover were small, restricting flow at full throttle, there was no provision for a pop-off valve, subjecting the filter canister and cooler core to pressures as high as 300 psi during a cold start, the inlet & outlet ports were separated by only a narrow land -- less than sixth thou as I recall -- the gasket of which had a habit of failing during a cold start, and -- perhaps worst of all -- the thing was made of cast
aluminum.
Most miss this last point because nowadays cast aluminum pump covers are enormously popular. Unfortunately, aluminum doesn't wear very well and the pump's steel gears will quickly grind a neat pair of circular craters in such covers. Since the end-clearance spec is only .002" as soon as that opens up you'd see a precipitous drop in both pressure and flow.
Given their years of experience and engineering expertise, I assume
Aerovee has solved all those problems. Along with how to keep the oil
clean without using a filter :-)
rizzz wrote:Now, for those of you who don't know about this Bob Hoover, he's probably the most knowledgeable VW expert the aviation community has ever seen,
Users browsing this forum: No registered users and 58 guests
