Fuel Flow Cube
Fuel Flow Cube
Postby GraemeSmith » Sat Apr 03, 2021 7:38 pm
ELECTRONICS INTERNATIONAL FUEL FLOW TRANSDUCER FT60 Red Cube - right? That's what everyone says. It's what Dynon and Garmin recommended on recent quotes to me.
But if you read the spec on Aircraft Spruce and especially at EI's web site - they specifically state that the red cube is "For use in Aircraft with engine-driven fuel pumps & Horsepower up to 350 HP"
For a gravity fed engine you need to go up to the FT90 Gold Cube. "For use in Aircraft with gravity-fed fuel systems or Horsepower between 350 to 500 HP"
Is this why some folks think they are having trouble with vapor locking in the fuel cubes? The red cube is actually not supposed to be used in a gravity situation?
Just throwing it out there for discussion.
Re: Fuel Flow Cube
Postby pappas » Sat Apr 03, 2021 7:56 pm
Yeah, I read the same thing. I did call Dynon and they said I could use the Red Cube with the Aerovee or Jabiru gravity feed systems. I ran the Red Cube in my Waiex 3300 gravity, RV-8 IO-360 Elec pump, and my current Waiex Aerovee Turbo gravity. The sensor is directly forward of the fuel petcock at the tank bottom and they were all accurate.
The red Cube is $100 less expensive than the Red Cube, so I saved the money and went Red.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Re: Fuel Flow Cube
Postby Spaceman » Thu Apr 15, 2021 6:35 am
I asked Kerry about this because I think the gold cube is actually called out in the B-model plans, even though the red cube seems to be more appropriate for the fuel flow of our engines. He said that gravity feed is the reason they recommend the gold cube. Not really sure why!!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Re: Fuel Flow Cube
Postby GordonTurner » Thu Apr 15, 2021 7:31 am
It’s the pressure drop.
Red cube .6 psi drop at 30gph
Gold cube .05 psi drop at 20gph
With our little bit of gravity pressure, 1/2 psi drop is significant. It may work ok in some cases, but it’s still a lot.
Re: Fuel Flow Cube
Postby builderflyer » Thu Apr 15, 2021 9:44 am
GordonTurner wrote:It’s the pressure drop.
But, as you know, Gordon, on Sonex products we're not running 30 gph. At 10 gph the red cube pressure drop is only 0.06 psi. Fuel flow testing confirms that the red cube works for many of us and because of a significantly lower price than the gold cube, it's been the chosen way to go.
Art,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,.Jabiru 3300 #261
builderflyer
Re: Fuel Flow Cube
Postby GordonTurner » Thu Apr 15, 2021 11:37 am
Thanks Art
The only info I saw didn’t include the really useful data points. .06 at 10 gallons sounds fine, $100 bucks in my pocket sounds fine (that won’t last long...).
Gordon
Re: Fuel Flow Cube
Postby AlexZ » Fri Apr 16, 2021 4:38 am
We have the Red Cube and it works perfect. Exact readings which corresponds to fuel usage from tank. We have the straight fuel line according the Jeff Shultz design. http://www.sonex604.com/misc/Sonex_1374_Fuel_Sys_Mar_2018.pdf
Alex
Flying:
Sonex Legacy TD PH-AWX Aerovee https://www.facebook.com/SonexPHAWX/
RV-7A PH-PWP
Building:
Piel CP1320 https://eaabuilderslog.org/?s=CP1320
AlexZ
Re: Fuel Flow Cube
Postby Darick » Tue Apr 20, 2021 2:28 pm
Red cube has worked fine for me.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Fuel Flow Cube
Postby mike.smith » Sun Apr 25, 2021 10:03 pm
I have had the Gold Cube (as recommended by the manufacturer) since I built the aircraft and it has not worked worth a darn. It's been pretty much useless, and I have a VERY simple fuel system with the device located per the manufacturer's recommendations. I bought a Red Cube this year and plan to install it during my condition inspection this summer. I'm curious to see if it works any better.
Re: Fuel Flow Cube
Postby XenosN42 » Mon Apr 26, 2021 10:18 am
mike.smith wrote:I have had the Gold Cube (as recommended by the manufacturer) since I built the aircraft and it has not worked worth a darn. It's been pretty much useless, and I have a VERY simple fuel system with the device located per the manufacturer's recommendations. I bought a Red Cube this year and plan to install it during my condition inspection this summer. I'm curious to see if it works any better.
Hi Mike,
I'm curious. What are the exact problems you are encountering?
What type of EFIS is the Gold Cube connected to?
-- Michael
OneX N169XE
XenosN42
